Belt pulley seal
BEL@ IN
09-03-2002 17:35:51
I have removed the pulley flange and attached gear from the gear box on a Super M to replace the seal. Am at a loss how to get to the seal. All I see is big bearings and a gear that doesn`t want to come apart. Are special tools needed? I am planning on putting this on my 450 and looks as if I`ll have to loosen the gas tank. As usual thanks in advance to all who would to comment.
Haas
09-03-2002 18:40:12
 Re: Belt pulley seal in reply to BEL@ IN, 09-03-2002 17:35:51
To get to that seal, the gear and bearings must be reomved. To do that, you will need a bearing press. Best to take the assembly to a shop that has one to press the bearings off the shaft and then back on again. That is what I did.
