300U Hydraulic Dipstick Reading???
Bob Kirk
09-06-2002 16:38:07
Somebody once said "there is no such thing as a silly question," only silly people afraid to ask what they need to know. I'm going to test this theory.
My 300U has its hydraulic reservoir under the seat. Near the front edge is a pipe-plug type cover for adding fluid, and attached to the cap is a dipstick a few inches long for measuring "full."
Here's my question: Am I supposed to screw the cap in all the way to accurately measure fluid "full" -- or do I measure by just setting the cap in the hole and not screwing it in at all??? There are maybe 3/4" of threads on the cap, so screwing it in might show it "full" while not screwing it in would show it pretty low.
My owner's manual is silent on this point. Help please! And thank you in advance.
Bob Kirk
dick
09-06-2002 21:44:27
 Re: 300U Hydraulic Dipstick Reading??? in reply to Bob Kirk, 09-06-2002 16:38:07
Really good question. I've always worked under the assumption that the plug was supposed to be screwed in. Seems to take about the right amount of oil to refill that way, and if it's filled up higher oil tends to come out the vent, so I believe I'll stick with doing it the way I have been.
Bob Kirk
09-07-2002 18:10:04
 Re: Re: 300U Hydraulic Dipstick Reading??? in reply to dick, 09-06-2002 21:44:27
Dick: Thanks for your reply. I've been doing it this way too.
I'm curious about your comment about oil coming out the vent. By "vent," do you mean the "breather" that sits on top of the reservoir or someplace else?
I've recently had oil spitting out around a snap ring on the top of the safety and flow control valve. This has coincided with my Hydra-Touch valve not working -- so I've figured something is clogged up and I'm about to rip things apart to see if they're full of dirt.
Thanks again for your reply. So far, its a flat-footed tie -- one to one -- on which method to use!
Bob
Red Rider
09-06-2002 20:34:20
I measure mine by just setting the plug in the hole not screwed in.
