Order Farmall Cub Parts Online
How do you adjust carb on cub????
Billy Lundstrom
09-08-2002 09:33:45
Can someone share a few tips on how to keep your cub running smooth. to much gas and it dies, shut fuel off, and it runs great till it burns up fuel in bowl. I have done everything except replace or kit the carb. this is a 1949 cub demonstrator model with white hood. any suggestions would be greatly appreciated. thanks billy in montana
billy ray
09-08-2002 12:36:23
 Re: How do you adjust carb on cub???? in reply to Billy Lundstrom, 09-08-2002 09:33:45
to clark, hey thanks for the tip, and the info.
My guess is the carb is warped, cuz I took it apart, and everything seems to be in tact and in place. should probably just order a new carb. but that can get expensive. about 180.00 less s & H.
thanks for the tip on the year of the machine also. Do you have a cub with the Hydraulics on it and the goodies that came with the tractor its self???
And do you know anyone that would be interested in some implements for the cub. I have a few that I would like to sell. Under belly mower, plow and spring tooth cultivator. if so, let me know please, thank you Bill
clark
09-08-2002 10:30:07
HI Bill, first of all the white demonstrator cub's didnt come out till early 1950.., there werent any 49 demos.. to answere you question about the adjustment on the cub carb is that the only real adjustment is the idle jet.. these IH carbs are prone to warpage from over the years of being taken apart and put together and screws tightened too much.. the thing to do is get a kit and take your carb apart ,, check all mateing surfaces for flatness.. if they are warped you possibly can fix the problem with a flat file enough to get the surfaces to fit tight enough for the gaskets to seal.. also check to make sure that the main jet hasnt been drilled out, if it has it willneed sodered and redrilled to proper size, then make sure the idle tube isnt broken off, if it is then you will have to replace it but getting the broken piece out of the top of the carb is a real challange..i would sudjest goint to atis under the farmall cub discussion board and loking in the arcives and finding out about replaceing the needle valve with a rubber tipped one, this will work great in stopping the leaky carb problems .
