Trans. prob!
Bryce Andreasen
09-09-2002 08:40:41
i have a '41 H and the pilot bearing has went out three times in one year. Is there anything that could be wrong? or is there another kind of bearing i can put in? any advice or ideas at all!
Andy Martin
09-09-2002 19:14:41
 Re: trans. prob! in reply to Bryce Andreasen, 09-09-2002 08:40:41
I assume you mean the pilot bearing internal to fifth gear. Check the inside of the cluster gear. It may need to be replaced. Also check to make sure the front bearing is good.
If you mean the clutch pilot bearing, check for a bent clutch shaft or damaged race.
