Tricycle front of h or m
Abdon
09-17-2002 14:48:21
Does anyone know the story of why there is a round head bolt thru the bottom between the spindles of the pedistal and was this made by a vendor for IH. also is the H and M pedistal compatable?
randy hall
09-17-2002 20:30:07
 Re: Tricycle front of h or m in reply to Abdon, 09-17-2002 14:48:21
the lower bolster is cast iron. the splindles are steel the rivet holds the splindles in the proper place in the lower bolster. the company that cast these for ih is the name you see on the front. i have four '39 m's and they have a different number and the ihc symbol cast in. i don't know when they changd for sure
Old Hand
09-17-2002 16:42:04
The bolt or rivet can be removed and spindles replaced as per ITT manual. Never found anyone who knew why bolsters are marked "Beletromal" this might be good question for Guy Fay.
Dick Davis
09-18-2002 02:29:39
 Re: Re: Tricycle front of h or m in reply to Old Hand, 09-17-2002 16:42:04
Abdon, the H bolster has a smaller bolt pattern than the M. I suppose someone has modified one to fit the other over the years, but the correct size is readily available. Dick
