Farmall M wheel
44
09-18-2002 07:51:34
Is their a set off wheel hubs off of something that will fit on my Farmall M axles i need to install some pressed steel wheels on the M to do away with some weight for pulling
randy hall
09-19-2002 08:33:14
 Re: Farmall M wheel in reply to 44, 09-18-2002 07:51:34
i have a pair of m & w hubs that i would sell. pullers i know won't use massey 44 hubs because they will break.
ohiompuller
09-19-2002 11:17:48
 Re: Re: Farmall M wheel in reply to randy hall, 09-19-2002 08:33:14
How much and where are you located?????
RPM
09-19-2002 06:55:18
IH that will fit are duals from F460HD, F560, 656, 666,686, these were all pressed steel rims and separate cast hubs, all these tractors have 2.75" od rear axle.
Geoff
09-18-2002 14:43:26
If you get hold of a copy of Red Power magazine there are ads for hubs for nine bolt wheels as you are describing.
Flyin Farmall
09-18-2002 19:24:27
 Re: Re: Farmall M wheel in reply to Geoff, 09-18-2002 14:43:26
Find a set form a Massey 44.They bolt right on and are lighter than Oliver hubs.
