M carb Question
37G
09-18-2002 16:14:47
have a chance to buy an M in good running condition for 700 bucks and i will buy it. The Carb is flooding out the engine when it runs and the man told me it works and then after a while it gets stuck. Is there a carb rebuild i can get fairly cheap with INSTructions install parts? I just want to replace the floa. Who has them and how much thanks
RPM
09-19-2002 06:22:43
 Re: M carb Question in reply to 37G, 09-18-2002 16:14:47
The carb gasket pkg is $23 from CNH, float valve $7, float $29. Very simple carb, no special tricks or tools.
Mr. J
09-18-2002 20:32:23
third party image
It is more than likely the needle valve and seat. This is the valve that stops the flow of fuel when the float rises with the fuel level. Usually, the float is not included in a rebuild kit, so you will more than likely have to order the float seperately. The rebuild kit in general is also available from just about any auto parts store. It will have new gaskets, new needle and seat, new seals, etc. Also, in the rebuild kit will be a schematic drawing of how the carb goes back together. It takes some patience, but I'm sure you could handle it.....good luck with it, just ask if you need anymore help.
Mr. J
Dave_Id
09-18-2002 16:51:29
It may just be the axle pin on the float slipped out.. Had that happen to me on a couple of units...kits you can buy at the Case/IH dealer
