Snowblower for Farmall 350
Andy Kopel
09-18-2002 18:29:39
I have recently purchased a Farmall 350 to do help with the work around my 20 acre hobby farm. I've been looking for a snowblower to remove the snow from my 500ft driveway in the winter. The 350 does have a loader, live power, and the fast hitch and I have located several sources to change it to the 3pt.
What size and type of snowblower would you recomend?
Are there any other modifications/additions to the tractor I can perform to make my job easier?
Thanks in advance,
Andy
Dick Davis
09-19-2002 04:23:27
 Re: snowblower for Farmall 350 in reply to Andy Kopel, 09-18-2002 18:29:39
My neighbor has a snow blower on his 300, it probably is a six footer. He converted it from a 3 point rear mount to a loader mounted up front affair. Really a great set up. (Most of us do better going forward than reverse!) He designed and built an under-the-axle PTO driven drive shaft that reverses direction of rotation. This guy thinks of everything. He also built an all weather cab with metal engine side curtains to gather heat. I think he prays for big snows now. Maybe I could take some pictures of his improvements. Dick
IowaWill
09-21-2002 20:11:36
 Re: Re: snowblower for Farmall 350 in reply to Dick Davis, 09-19-2002 04:23:27
I have a 5' that I rear mount on my 300. I have a 3pt. It is a little too narrow to get the whole tractor behind so I have to work my way in to bigger drifts. Just the same, it is a load for this tractor - I don't know but I assume that a 350 has approximately the same hp. I would think a 6' would work it pretty hard. Good luck.
Andy Kopel
09-19-2002 05:07:13
Hey,
That sounds like fun. If you're over there some time take a couple pictures and throw them my way.
Andy
Don LC
09-19-2002 06:46:51
 Re: Re: Re: snowblower for Farmall 350 in reply to Andy Kopel, 09-19-2002 05:07:13
Post them for us all too see....thanks Don
350 Don
09-18-2002 18:51:49
If you already have Fast Hitch conversion to 3pt is simple. Buy the conversion arms that slip right into the existing fast hitch openings, and add a bracket for the upper arm and you are in business. It allows you to use fast hitch when you want and 3pt when you need it with less than a minute conversion time. As to the snowblower, your best bet is to check with your local dealers and compare for yourself. Unless you live where you get a lot of snow maybe your loader with a blade on it instead of a bucket could do the job for you. I have a wide bucket on mine that is for snow.
