Best fluid for Lift-all.
Bob G
09-21-2002 20:25:53
What is the best fluid to put in the lift-all? I will be using only a sickle mower on the hydraulics. What is the easiest way to change the fluid? Take off the bottom line and let it drain. What is the capacity of the lift-all?
Thanks,
Bob G
Steven@nd
09-22-2002 09:56:33
 Re: Best fluid for Lift-all. in reply to Bob G, 09-21-2002 20:25:53
I use Hy-Tran in my Liftall on my H. It works good for the sickle mowers and cultivators for the trees. If you want to lift something much heavier you will need the 30W non-detergent oil for more pressure. Why non-detergent? Because in a hydralic system detergent oil will foam and that's not a good thing. Hy-Tran will not foam and neither will the non-detergent oil.
Steven
Old Hand
09-22-2002 03:48:41
There is a drain plug in bottom of liftall. Capacity is 6 quarts 30W non detergent motor oil.
Wayne Swenson
09-21-2002 20:56:02
Go to the Research & Info site on the left side of this page and try Articles or Search for " Lift-all" and you will get lots of info.
30 weight non-detergent oil is your best bet for the old systems.
oil me up
09-21-2002 20:35:26
doesn't anyone ever buy a manual for thier tractors? would this be too simple?
gene b
09-22-2002 03:03:20
 Re: Re: Best fluid for Lift-all. in reply to oil me up, 09-21-2002 20:35:26
manual is the first purchase after getting tractor to eliminate all the old wives tales that appear on this site
Dick Davis
09-22-2002 03:20:41
 Re: Re: Re: Best fluid for Lift-all. in reply to gene b, 09-22-2002 03:03:20
Not to under value manuals but some info that was valid 50-60 years ago isn't correct today. Check the archieves for ND and detergent oil use discussions. Or ask the H & M operators how often they change the transmission oil in their tractors. (Seems to me I read that for heavy use change all 15 gals TWICE a year). A lot of progress has been made in the lubrication products. I consider this forum to be an excellent source of current info. And most out of line comments are corrected PDQ. Dick
Redtractorman
09-22-2002 16:42:45
 Re: Re: Re: Re: Best fluid for Lift-all. in reply to Dick Davis, 09-22-2002 03:20:41
Detergent oil can not be used in hyraulic systems,because they foam and I know this for a fact.
