Have I found hubs for duals??
Bryan
09-24-2002 10:26:32
I found a set of hubs which appear to be duals for a tractor. They appear to bolt to the cast center of the inside rim with four bolts. (Approx 11" on center bolt holes)Then they are about 12"-16" long and have 9 studs on the other end. Heavy cast iron things they are, roughly 80+ lbs. They are marked Kalida and I have found a manufactuer in a town by that name that makes wheel systems but can't find any reference of these exact parts. They won't fit my 460 because my bolt pattern is 12" on center so what are they for? Also, how does the 9 bolt pattern work, do you have to buy a special rim for that? Thanks for the help!
Dr. Evil
09-24-2002 19:10:21
 Re: Have I found hubs for duals?? in reply to Bryan, 09-24-2002 10:26:32
The adapters sound like a pair of direct axle dual hubs for a tractor that doesn't have bar type axles. I know something similar was made for Allis-Chalmers WD-45's & D-17's. The 9-hole bolt pattern was a standard pattern for stamped steel disc wheels back in the 50's & 60's. Should be able to find a wide selection of sizes to fit that pattern. As for the wheel weight bolt pattern, It sounds like Your adapters are for something other than an IHC. Everything from a C to a 686, including ALL the H, M, 300/400, 400/450,460/560 took the same wheel weight which means they had the same hole pattern. A 460 should have the 2-3/4" axle diameter... LOTS of dual hubs made for that axle size... by IH, Peterson, Unverfurth, & others. I'd buy them... the wheel weight adapters would put too much stress on Your wheel clamps like a clamp-on dual and could crack Your stock spoke wheel hub.
