Order Farmall Cub Parts Online
? Cub plow parts
Alvin NE WI
09-24-2002 12:34:02
I finally got my Cub together after sitting many years.Also have a plow for it with hydraulic lift. Can some one either post a picture or explain to me what I have missing. I have the lift chain on the plow. Where does it go? Old age does take the menory and put it somewhere!!! I also have a cross bar that goes on the end of lift arm. Thanks Alvin
Tom W
09-24-2002 17:12:38
 Re: ? Cub plow parts in reply to Alvin NE WI, 09-24-2002 12:34:02
Alvin, the draw bar on the cub has to be turned around backwards and one bolt has to be taken out of each side of the draw bar, so when the draw bar is attached to the front holes, it can move up and down. The plow bolts to the draw bar , off center to the right. The chain on the [plow attaches to the lift arm on the rear of the tractor. You also new a draft control lever that attached to the draw bar. The right hand wheel has to be turned in close to the fender. I don't have mine on the tractor yet or I would send you pictures
Alvin NE WI
09-24-2002 18:22:34
 Re: Re: ? Cub plow parts in reply to Tom W, 09-24-2002 17:12:38
Guess I have everything I need than. Thanks for the info. I did remember about the draw bar part.
