H Operating Temp
B. Batty
08-22-1999 16:37:50
What's normal operating temp. for an H?
ltf in nc
08-23-1999 20:14:39
 Re: H Operating Temp in reply to B. Batty, 08-22-1999 16:37:50
The thermostat(s) control the operating temperature. They should be modulating the temperature at all times and the radiator should be able to cope with the heat dissipation at the maximum horsepower of the engine. If the temperature is rising above the thermostat rating there is trouble with the cooling system. No exception.
The Red
08-23-1999 02:01:12
The thermostat should start opening around 160 degrees. Under heavy loads it can get as high as 200.
Corky
08-22-1999 21:55:36
180 degrees is about normal
