Need help on flywheel for 29' 1020
brandon cerrite
09-26-2002 19:15:56
i am restoring a 1929 mcormick 1020 i have the engine torn down pretty close to a bear block all i need is to remove the crank but i cant get the fly wheel off there is a round key about 3 1/2 inches long thats threaded inside but cant get it out any info on this would be much apprieated
casered
09-28-2002 07:17:26
 Re: Need help on flywheel for 29' 1020 in reply to brandon cerritelli , 09-26-2002 19:15:56
Brandon, we had this same issue on our 26 15-30. We made our own slide hammer from a piece of rolled steel and threaded the end to fit in the pin. Soaked it good with penetrant and pulled it right out without any troubles. The flywheel on the other hand was a different story. I made a puller out of 3inch c channel. I cut a length of it in two pieces and welded it together to make a "T". Drilled holes in the three ends to match holes in the flywheel and using heavy grade bolts we tightened the puller down against the end of the crankshaft pulling the flywheel off, with a little persuasion with a sledgehammer and lots of penetrant. Also cleaned the end of the crank real good with emery cloth to make the flwheel slide over it easier. Good luck and let us know how you make out.
ronohio
09-27-2002 14:15:34
Brandon, I just pulled the flywheel off a 10 20 engine without removing the pin with no problems that have shown up to date. Someone on here told me to use chains on the flywheel and a hyd. jack against the crank (I think) and it came off. At least that is how I remember it. Good luck.
F-Dean
09-27-2002 04:07:58
Brandon, I am stuck at the same place on my project to replace the main bearings on my W-30 which has a very similar engine. I plan to try a 3/8 threaded "Eye Bolt" and a slide hammer this weekend. Good Luck!
Brandon Cerritelli ..TO JERE PA
09-26-2002 19:44:59
Jere, thanks, im a 16year old and its taken me my father and lots of good old guys to figure this out, thanks for shedding light on this. if i could get ur email i need lots of help on this email me Smashm9899
JerePa
09-26-2002 19:27:23
There was a special slide hammer that dealers had to pull the key. Similar to the modern ones shops use today. All you need is the threaded bolt to screw into the key welded to a adapter to fit the threaded part of the modern slide hammer puller. Hope this isn't confusing. Jere
