What's the number of the disc plow for a Farmall A?
AGEN
09-27-2002 13:08:34
I have a two bottom disc plow for my Farmall A, but I don't remember the model number. I am looking for a manual for the plow (looking at E-bay)and wish I could remember the model number. It's the two bottom disc plow that fits a Farmall A with a rubber tired trailing wheel. It also has the rod that runs from the plow, under the tractor, up to the tractor's front axle (attaches above the right spindle) to help turn the plow. Does this ring a bell to anyone? Thanks.
Mike (TX)
09-28-2002 22:58:01
 Re: What's the number of the disc plow for a Farmall A? in reply to AGEN, 09-27-2002 13:08:34
Kendall, can you email me please. The picture you posted is just like the plow I found in back of the field. Could not find out what it was, until I saw you pic. I need more information
Email michael.hoelscher2@gdgsc.com or mhoelscher@earthlink.net
Mike (TX)
gene b
09-29-2002 00:31:37
 Re: Re: What's the number of the disc plow for a Farmall A? in reply to Mike (TX), 09-28-2002 22:58:01
do you want to sell it?
Mike (TX)
09-29-2002 04:56:36
 Re: Re: Re: What's the number of the disc plow for a Farmall A? in reply to gene b, 09-29-2002 00:31:37
Not really, I would like to restore it if I can.
Mike (TX)
Kendall
09-28-2002 09:40:34
third party image
let me see if I can instert pic.
Kendall
09-28-2002 09:39:06
Here's a pic of an A-151. Does it look like this?
Farmalldan
09-27-2002 20:58:20
On page 235 of "150 Years of International Harvester" is a picture of the A-147 disc plow. With the exception of the trail wheel being steel, it pretty well fits your description. There is no picture of the A-151 disc plow, so I can't compare it. It may be an improved replacement. The B-15 plow is for a model B. The same book shows (on page 208) the A-12 lister with a front attached beam like the moldboard plow and the A-14 lister with the reduction gear case mounted frames like a B lister.
AGEN...or the Lister Plow/Middlebuster number
09-27-2002 13:27:47
How about the middle buster/lister plow for a Farmall A. Is the that unit a B-15? Thanks!
