Farmall H clutch?
Bob
10-06-2002 18:32:12
Recently when I rebuilt the motor in my H I replaced the clutch disc, pressure plate, throw-out bearing, and pilot bearing. I think the clutch may need adjusted because it grabs very quickly, like when I let it out the tractor wants to bring the front end up.And when going in reverse it jerks as i let the clutch out. How would I go about adjusting the clutch? Thanks Bob
Steven@nd
10-06-2002 20:17:56
 Re: Farmall H clutch? in reply to Bob, 10-06-2002 18:32:12
No adjustment for that. Something is wrong with either your pressure plate surface, flywheel surface, or the surfaces on the clutch disk.
If it wasn't spotlessly clean when you put it together it can do that. I've had clutches chatter because of 1 drop of oil on them. I always clean with brake parts cleaner then use clean rags to handle the parts so I don't even get a finger print on them.
It could be something else, but I wouldn't know what it is.
Steven
