McCormick-Deering What is it?
AgMan
08-23-1999 16:07:27
Found this at a juck shop. It has a crank and eight gears. Tag says it is a blade sharpener. I'am not sure. Looks like something to wind up a belt? It has a clamp that looks like it would fit on a roung pipe. A spindle that has small teeth and moves up and down as it turns. Casting numbers P124,p120,p130,pb-111,pa-113,p109
Marked McCormick-Deering and has numerous little IH marks. Ain't red stuff great!
AgMan
08-24-1999 08:01:06
 Re: McCormick-Deering What is it? in reply to AgMan, 08-23-1999 16:07:27
Thanks for the help with the ID! I knew you guys would know.
Lyle
08-23-1999 16:43:05
Mower knife sharpener. I have 2 of them, one is IH, the other one is marked like yours. You should have a stone on it. You could clamp it to the wheel of your mower while in the field, sharpen your cutter knives, and keep on moweing. Yes, RED STUFF is great. "RED POWER RULES"
jason
08-23-1999 16:38:21
it sounds like a sickle knife sharpener used to sharpen the blades os a sickle bar mower. does it have a grinding stone on it. hope this helps
Village Blacksmith
08-23-1999 17:35:07
 Re: Re: McCormick-Deering What is it? in reply to jason, 08-23-1999 16:38:21
When you say sharpen the blades, are you referring to sharpening the mower sections??
