Farmall H Carburator
Bob
10-08-2002 21:12:42
I'm working on a 1942 H whose maintainance and repair history is unknown to me, It has some carb problems - sometimes starts, but is hard to keep running until it warms up, other times it wont start at all - it will fire for a second if you shoot some gas into the carb, but quits as soon at that runs out. My plan was to take a look in the carb. I went to my local International dealer to get a gasket kit for the carb, but all they had to offer was a "very complete" rebuild kit for $75.00. Now, I may need this kit, but in case I dont, does anyone know of a source for a simple gasket kit for the carb? Thanks in advance for any info.
The Red
10-09-2002 10:07:14
 Re: Farmall H Carburator in reply to Bob, 10-08-2002 21:12:42
Open your high speed mixture screw 1/2 turn.
Don LC
10-09-2002 04:44:25
Go to your "TRACTOR SUPPLY STORE" with the numbers off of your carb..... .you will need the parts in this kit..... .then take back the $75 kit.....Don
jal-SD
10-09-2002 08:48:30
 Re: Re: Farmall H Carburator in reply to Don LC, 10-09-2002 04:44:25
Your dealer should have the carb gasket as a separate item. Bought one for my '44 H just a couple of weeks ago from my dealer. If I remember right, they are the same for both types of carbs. Also get the gasket that goes between the carb & intake-when these leak, they can cause the problems you describe. They are available separately, too. (My $0.02 worth. jal-SD)
