Sticky Govenor and carb leaking super C
Brian Ordway
10-09-2002 16:20:21
I have a '51 super C while discing my pasture it acted like it was chokeing out on a hill, I moved the rod that goes from gov to carb back and forth and stared to run better had ot do that a couple of times lube both ends seems to correct to problem, is there something that I should look for during mantaince? and also the carb if I don't watch it like I should will start leaking gas all over the side, thanks for any help on this
Craig
10-10-2002 08:53:27
 Re: Sticky Govenor and carb leaking super C in reply to Brian Ordway, 10-09-2002 16:20:21
Those needle bearings and shaft inside the governor housing are notorious for rusting after 50 years. I'd check that out too.
Wayne Swenson
10-09-2002 21:18:44
Sounds like the carburetor needs a good cleaning, possible needle & seat replacement, and then carefully check the float to see if it has a hole causing it to ride lower and allow a high fuel level.
