1944 M
Brad Kimball
10-12-2002 22:29:12
How do I tell if my M has a internal "Lift-All" hydraulic system?
Doc
10-12-2002 23:52:10
 Re: 1944 M in reply to Brad Kimball, 10-12-2002 22:29:12
You will have 2 1/2" pipe thread outlets out of the left sidr of the clutch housing and 1 out of the left along with a rod from the left side of the clutch housing rearward to a frame coming rightward of the the light switch assembly. I'm sorry if this sounds complicated. I have a 42 M which I have done a lot of work to. Email with further questions, glad to help. Doc
Farmer Bob
10-12-2002 23:45:02
Brad, If there is a control arm coming out of the right side of the torque tube underneath the belt pulley drive, and one elbow on the right and two on the left side of that tube, you more than likely have the liftall. There is an inspection plate on the bottom of the tractor that you can remove and look up in there for a large round shaft connecting the transmission and the liftall pump. Sometimes that shaft is removed if they didn't want to use the lift-all.
FB
