Superc governor
bob
10-18-2002 17:04:17
where can i find a governor for my super c and how much should it cost? also, is it a job for a diy or pro..
BIG JOHN
10-20-2002 14:23:53
 Re: superc governor in reply to bob, 10-18-2002 17:04:17
There is a complete govenor for a "C" on E-Bay today Item #1779548182. I think that most parts will enterchange with a "Super C". CHECK IT OUT.
REA
10-19-2002 23:01:47
Hi Bob, * first check all the linkages making sure all works good without any interferance. * If this is ok then you may want to disassemble the governor and inspect the parts inside. Usualy the spring is broken, or where it attaches the hole is worn. If hole is badly worn have it welded, to its new position. You may have to redrill the hole. * Also the hole where the rod lever rotates may be badly worn, if so you will have to refurbish this with a sleve. Hope this helps! Bob
BIG JOHN
10-18-2002 19:14:58
From what you have said I can't tell what parts you need. If it is the governor drive gear only with the weights, I bought one from a salvage yard for $50. The thrust bearing is about $20 new. Hope this helps
