Finish mower on 140
Bill
10-21-2002 07:25:30
Has anyone used a finish mower (rear mounted 3pt.) with a Farmall 140? How well does it work? I'm considering getting a mower for mine.
And what is a GOOD condition 140 worth?
potosi
10-21-2002 18:03:20
 Re: finish mower on 140 in reply to Bill, 10-21-2002 07:25:30
I use a woods three point on my 140.My tractor has fast hitch so I converted the three point over to one point fast hitch.The fast hitch has some laterial adj.so you get the mower close enough in line with p.t.o. It works great,easy to disengage to use tractor for other things.
Dean
10-22-2002 09:01:25
 Re: Re: finish mower on 140 in reply to potosi, 10-21-2002 18:03:20
Can you detail how you converted the three point hitch to a one point fast hitch? I have thought about this but I was concerned anout the connection to the PTO as it is offset.
Thanks
K-Mo
10-21-2002 16:50:37
I have had the same thought for my Super A but have wondered if the offset PTO would be a problem with the 3-point PTO drive units.
Does anyone have experience with using 3-point PTO drive finish mowers with a Super A or 140?
K-Mo
K-Mo
10-21-2002 16:50:11
K-Mo
Pete in PA
10-21-2002 13:37:02
 Re: Re: finish mower on 140 in reply to Dean, 10-21-2002 09:49:29
Hey all...
I've got a 140 with a Woods L59 belly mount (59"). Love it, but have also considered adding a pull behind as you've done Dean. How much of a hassle is this? I assume you mount it offset to the belly mount. Do you have problems with drift over?
Pete
Dean
10-22-2002 08:56:52
 Re: Re: Re: finish mower on 140 in reply to Pete in PA, 10-21-2002 13:37:02
Pete,
I offset the swisher so that I get about 10 to 12 inches of overlap between the belly mounted mower and the pull behind. I don't have any problem with drift over but you have to plan your turns otherwise you end up with little uncut patches. Not really a problem.
