Order Farmall Cub Parts Online
Noise from Hydraulic Unit on Cub???
B. Mahar
10-26-2002 15:17:30
I am new to the world of cubs, and have 2 questions about the noise I am getting out of the hydraulic unit. When I raise and lower the rockshaft I get quite a bit of whine out of the hydraulic unit. Is this noise acceptable? Secondly, I had no problem all summer long when plowing. But recently I attached the snow-plow and now when I start the tractor I hear short, repeated "whines" from the hyrdaulic unit every 4 or 5 seconds whether at idle or driving around. During these short squeals the engine labors momentarily. It sounds as though the touch control is being activated in short bursts, and it occurs when the plow is raised or lowered. Any help would be greatly appreciated by this beginner. Thanks in advance.
Blair in Savoy, MA
gerald
10-26-2002 16:05:45
 Re: Noise from Hydraulic Unit on Cub??? in reply to B. Mahar, 10-26-2002 15:17:30
Had similar problem on my IHC 140. Checked fluid level of unit and found it 3 pints low. Filled it up and noise went away. Have you checked the fluid level?.....Gerald
don
10-26-2002 19:27:14
 Re: Re: Noise from Hydraulic Unit on Cub??? in reply to gerald, 10-26-2002 16:05:45
I agree. It sounds like it is low on fluid and now has air in the lines. Fill it to the full mark and then cycle the hydraulics a few times without the fill cap on to bleed the air.
