Winter starting
blarson
10-27-2002 15:31:18
I plan to remove the battery from my cub for the winter But would like to start it periodically during the winter. Would it hurt the generater or relay to start the cub (magneto ignition) with the hand crank without the battery hooked up
Bob M
10-27-2002 17:59:54
 Re: winter starting in reply to blarson, 10-27-2002 15:31:18
So long as the clamp on ungrounded battery cable doesn't touch any grounded metal part while the motor is running, operating a generator-equipped tractor without a battery won't hurt a thing. (I've done it many times). Suggest wrapping the ungrounded battery clamp with electrical tape to be sure it doesn't become accidentally grounded.
Note - The ungrounded battery clamp will be the negative one if your tractor is positive ground.
TomH
10-27-2002 15:48:42
I vaguely recall reading something about possible damage to the generator if there's no battery. Can you just loosen the belt so it doesn't turn.
