Motor oil for Farmall
Bill
10-28-2002 06:39:19
Is Havoline 5W-30 a suitable oil for a Farmall 140? If not, what is? It's a mid 60's model.
CNKS
10-28-2002 18:50:42
 Re: Motor oil for Farmall in reply to Bill, 10-28-2002 06:39:19
Just put 15W-40 in it and run it year around. If you use it in a LOT of cold weather, 10W-30 might make it start easier.
RPM
10-28-2002 06:53:03
No, IH would tell you 10w low ash in 20% weather and below, 30w in above, no matter what you are doing, heavy light or moderate loads/speeds. Low ash cures spark plug deposits, I worked at IH dealer since 1960 and it does cure the problem, 560/706 series were terrible about this in heavy tillage, if you dont want IH oil get 10 or 30 from sopmeone and specify low-ash or lpg specs.
560GMAN
10-28-2002 07:31:05
 Re: Re: Motor oil for Farmall in reply to RPM, 10-28-2002 06:53:03
ok rpm, I have a 560G in swmn.It`s used for very light work. (scooping snow,etc.)What oil should I be using in the motor and oil cup? Plugs? Gas?
sammy the RED
10-28-2002 09:04:26
 Re: Re: Re: Motor oil for Farmall in reply to 560GMAN, 10-28-2002 07:31:05
10w30 for winter.
30 wt. for summer.
