1466 Questions
Need Input
806 Southern In
10-29-2002 09:14:04
I know this has probably been discussed before but thought I would ask anyway.
Am looking at a 1466 with 5500 hours on it. Overall appears in decent shape, needs paint. When I drove it the torque seemed to hold and brakes as well. 3 point worked but noticed the hytran was over the full mark. Also noticed when you idled the engine down the power steering went away. Talked to the last owner(2nd owner) and he filled me in on a couple things. When he owned it he had problems with the 3 point not raising. Talked to an IH mechanic and he said there is a small oring inside on the suction tube that could be leaking and drawing air. Told him he could either over fill it or remove the pto housing and replace the o-ring. After the owner overfilled the hytran the 3 point worked fine. I'm thinking I've heard of this issue before has anyone? Also the remote are not working well in that the owner tried to use it on a drill and it would not raise the drill very fast at the end rows when idling the engine down. Is that possibly connected with the loss of power steering and any ideas on the problem. The engine and PTO has been overhauled about 700 hours ago. Got the dealer down to $6500. Is that still too much? Also noticed the front end is very loose. Does IH make any kind of rebuild kit for the front ends? Any commnets as always are greatly appreciated.
joe
10-29-2002 20:18:17
 Re: 1466 Questions - Need Input in reply to 806 Southern In, 10-29-2002 09:14:04
heck, i'd buy it! That's a LOTTA LOTTA tractor for that price, and none of its problems sound real extra serious, in other words, you can probably fix them all pretty easy and cheap.
TL
10-29-2002 19:03:47
I just sold one this spring.It had new tires,paint,5500hrs.They make a taperspline to fit on top of the spindle that the tie rod connects to,that solved most of the play with that one.It was a fender tractor,no problems with hydraulics though.I got 7500 for it.Southeastern Indiana,Versailles area
AceS
10-29-2002 10:36:47
You should be able to rebuild the front end. The only thing that would efect both hitch and power steering both would be an air leak on the sucksion side and filter over filling would help if it has air leak if not have the dealer test the pumps for flow and pressure if he wants to sell he should test.
