Help me decide
Bob
10-30-2002 21:23:32
Have a '49 Super AV in running condition. Block has been patched behind the carb with a plate and screws. Doesn't leak but looks like heck. Brand new 11x36 rears with new tubes, non AV rims and car tires on front. Steering is loose, one tierod arm has been welded to the spindle, clutch needs to be replaced, sheet metal is so-so, grille is rough, no lights with mag.
Should I part her out or attempt to restore it knowing I'll have more in it than it would sell for. No sentimental issues with it.
Bama Binder
10-31-2002 07:58:37
 Re: Help me decide in reply to Bob, 10-30-2002 21:23:32
If you were going to restore, it would be tempting to buy a second Super A and swap the parts until you have a good Super AV and a rough A and sell it for parts. A lot of work, but you would probably not do too bad on the money and get a neat tractor in the deal.
Steven@nd
10-31-2002 06:50:08
I would restore. There are few Super AV's out there and they will continue to go up in value. Check with a salvage yard about a replacement block if it bothers you. I got one for my H for $200.
Rims should be easy to have a welding shop make with the proper dimensions and a few pictures.
SAm in NS
10-31-2002 03:51:18
If it was me I'd be trying to restore her, all depends on what you want the finished product to be. SAm in NS
Jonathan Mirgon
10-31-2002 06:59:04
 Re: Re: Help me decide in reply to SAm in NS, 10-31-2002 03:51:18
I bought an (a) to restore that was in about the same condition as yours, block and all, I bought it to restore, after complete engine rebuild and replacing all the missing parts, I figure that I will have over 4,000 dollers in it. It can get costly and I know I have invested far more than its worth. Id keep the old AV they seem to be getting rare, You can do like me and just spend a little each month until its done, theres no hurry !
good luck
Bob
10-31-2002 20:20:21
 Re: Re: Re: Help me decide in reply to Jonathan Mirgon, 10-31-2002 06:59:04
Thanks to everyones replay, the decision was easy, the Super AV will be a keeper!
