F-14 Magneto
BC
11-01-2002 16:12:14
OK heres the deal,14 refuses to run.Got gas for sure!(Pulled it so much gas was coming out of the muffler in specks,Had to wash it off)Took mag off and spun it over with impact wrench.Got spark across safety gap,than it stopped.Cleaned everything up and spun it over again,still no spark.Put on cap and put a plug wire in number 1 hole.Held wire and nothing,not evn a tingle!BY accident hit the reverse button on impact wrench and got the living sh,uh dookey,knocked out of me.Spun it backwards after I shook the shock from my hand and had spark for a few seconds and then it went away again,Spun the mag right same thing,good spark then nothing.Anybody got a clue as to what is going on with it?Maybe condensor?Im open to any suggestions.
F14
11-02-2002 01:08:07
 Re: F-14 Magneto in reply to BC, 11-01-2002 16:12:14
Condenser would be my first guess. Certainly a cheap enough guess to try.
MikeH=Tx
11-02-2002 11:28:22
 Re: Re: F-14 Magneto in reply to F14, 11-02-2002 01:08:07
Agreed. Spinning it backward changes the polarity of the current flow. Condensor might be bad in one direction only. Wierd, but possible. Also check the points. Maybe spinning it backward opens them but spinning forward doesn't (points set to close).
