Should fire go to starter with ignition switch off
abane
11-01-2002 16:45:55
I had a starter taken off and rebuilt on a 350 diesel and when I put it back on, I had fire going to the starter with the switch off.Should this happen and if it's not suppose to ,what might be the cause?
Bill L Md.
11-03-2002 06:49:16
 Re: Should fire go to starter with ignition switch off in reply to abane, 11-01-2002 16:45:55
I don't about that Red Man I am familiar with the 400 that we had and it had a key switch. Wouldn't that be the same as in your car were you only get juice when you turn the key to the on position.I will agree that you are currect with the letter series because all the kill switch does is ground out the points. But doesn't that all change with the number series? We had that same 400 start by its self one night,ran up against the barn sit there and fry ,thank God for the dogs,only lost the wireing harness and a good portion of the paint, (gas was turned off)we got their just as she spit her last ,and put the fire out .All caused by a short in the electrical system.
don
11-03-2002 19:22:44
 Re: Re: Should fire go to starter with ignition switch off in reply to Bill L Md., 11-03-2002 06:49:16
My 300 has the solenoid mounted on top of the starter. So the one side of the solenoid is 'hot' all the time.
Glenn(WV)
11-01-2002 18:46:04
Same for my Farmall 100; I can crank the starter over regardless of how the ignition switch is set.
BillWV
11-01-2002 16:57:14
I can't speak for your tractor, but for my A, the starter has hot connection (in my case, negative, 'cause it is a positive ground system) all of the time. The starter button completes the ground circuit, causing the starter to run.
Bill
Red Man
11-01-2002 16:58:18
 Re: Re: Should fire go to starter with ignition switch off in reply to BillWV, 11-01-2002 16:57:14
Yes you should have fire at the starter.
