1954 SMTA
Andy47
11-03-2002 09:07:35
When shifting into gear with the TA disengaged, does the Transmission always grind? It does not when the TA is engaged.
Thank You
Hugh MacKay
11-03-2002 13:55:00
 Re: 1954 SMTA in reply to Andy47, 11-03-2002 09:07:35
I agree wholeheartedly with Dan and Steven. Just like to point out use the manual diagram on adjustment. Close is not good enough on these TA equiped tractors.
Steven@nd
11-03-2002 09:47:54
If it grinds when the TA lever is ahead, but not when the TA lever is back you need to adjust your linkages.
When you push the clutch in, it is supposed to also disengage the TA clutch - just like if you were to pull the lever back.
Dan
11-03-2002 09:39:15
Andy, have a SMTA also. I don't have any problem with gears grinding with TA either way, I imagine the problem is linkage adjustment. Clutch and ta clutch have to be adjusted together to work right. It is a sort of complicated procedure but is shown in operator's manuel.
