Farmall 140
44
11-04-2002 18:03:47
I have a farmall 140 bad block I have a super C
motor in good shape is this the same motor
as the 140 I was told it would fit only difference I can find is the location of the water pump the 140 pump is higher up under the head did all 140 have this type of pump or was this a running change was their 140 with two types of grills may be late & early.
was this a 123 motor
Hugh MacKay
11-04-2002 18:13:43
 Re: Farmall 140 in reply to 44, 11-04-2002 18:03:47
The C-123 engine will fit, you may have to use the 140 water pump and maybe a few other items on front of engine. You may not have to change anything. There may be some benefit in using carb, manifold and breather from your 140.
