Governor on '51 Super C
Brian Ordway
11-06-2002 20:08:06
I lost throttle control to the governor on my 1951 Super C. The upper arm moves back and forth but no action from the lower arm to the carb. When at idle, I can feel tension on the lower arm and can increase the idle. Is there a rebuild kit for the governor or will I have to take it to a shop? Any info will be very helpful. My tractor needs to get back to work.
gene b
11-07-2002 05:02:22
 Re: Governor on '51 Super C in reply to Brian Ordway, 11-06-2002 20:08:06
There is a spring in the gov housing and that mite be broken if you dont get any response at all just fast idle. Do be careful taking apart as the geat that runs it must not be removed or you will get engine out of time. SO be careful just take gov housing off and let the rest in place.
