Farmall C stationary engine\ need carburetor
Brent Prisby
11-07-2002 17:44:43
Hi my name is Brent Prisby, I have recently bought a farmall engine at an auction, it is different it sets on the ground it has a radiator and a gas tank its a thing that must have powered an irrigation pump or something if anyone can tell me what it is used for let me know... I also need a carburetor for that engine it is a C-23 thanks-brent
Brent Prisby
11-11-2002 11:25:44
 Re: Farmall C stationary engine\ need carburetor in reply to Brent Prisby, 11-07-2002 17:44:43
Hi my name is Brent Prisby, I have recently bought a farmall engine at an auction, it is different it sets on the ground it has a radiator and a gas tank its a thing that must have powered an irrigation pump or something if anyone can tell me what it is used for let me know... I also need a carburetor for that engine it is a C-123. It has a place for a starter, and an alternater, it is also hand crank, How do you start this hand crank without breaking your arm?
thanks brent
gene b
11-08-2002 01:26:52
Could have came off a combine a hay baler a windrower or maybe was just a engine called a power unit to run a sawmill or a pump of anykind. A carb for an A,B,or C will work. Prices vary from 150 on up. What type of sheet metal does it have where is the starter is there a plate below the dist covering up the hole for a hy pump. Is there a plate in front of the filter covering up the mt for a fuel pump? Where is the starter? Is there a generator? Does it have a clutch? Hard to tell without seeing the engine.
Brent Prisby
11-11-2002 11:22:11
 Re: Re: Farmall C stationary engine\ need carburetor in reply to gene b, 11-08-2002 01:26:52
It has a clutch, there is no starter bet there is a place for one on the left of the engine, there is no generator but it is possible to put one on
bp
probably a C-123
11-07-2002 21:56:18
probably a C-123
