I-4 Headlights ?
Ben C.
11-09-2002 14:38:32
Hi, Did the I-4 have headlights ? If so Where did they mount ?
Thanks,
Ben C.
garyz
11-10-2002 11:13:58
 Re: I-4 Headlights ? in reply to Ben C., 11-09-2002 14:38:32
The brackets can be hard to find. I spent 8 months locating some. And found them. However, of interest---the brackets are the same on the W6 and W9. They have tear drop shaped holes and will take 1/2 and 5/8 bolts. So will fit the W4. I got mine off a W6 and they fit just fine. Try one of the North Dakota salvage yards, they probably can find what you need quicker than I found mine.
BIG JOHN
11-09-2002 15:54:54
The W-4 & I-4 had the same mountings and location. The O-4 & OS4 had light and mountings located under the grill to protect them from tree limbs.
Ben C.
11-09-2002 16:27:20
 Re: Re: I-4 Headlights ? in reply to BIG JOHN, 11-09-2002 15:54:54
Thanks for the help. Do you know of any good photo's of I-4's. I found the one on here. I-4 pictures seem scarce.
Ben C.
BIG JOHN
11-10-2002 17:39:17
 Re: Re: Re: I-4 Headlights ? in reply to Ben C., 11-09-2002 16:27:20
Get a copy of Guy Fays "FARMALL Letter Series Tractors". You will find several pictures of W-4's, O-4's, OS-4's and I-4's on pages 67 thru 75. Some with lights and some without.
John (SC)
11-09-2002 15:51:26
Ben,look on the side of your 4 just below the radiator on the main casting.Youll find oles for the mounts that hold the headlight on.Also on the front just below the grill on the boittom of the casting there are some more of those holes for the brakets.The rear is under the platform for your feet on the right side as if you are sitting on it.
