Farmall 300
300win
11-10-2002 14:16:13
I've seen more than one spec on the top rpm for the 300. Some say 2200 rpm. The most I seem to be able to get out of mine is about 1950. Am I missing something??
Red Rider
11-10-2002 21:25:08
 Re: Farmall 300 in reply to 300win, 11-10-2002 14:16:13
My 300 Farmall has the high Idle RPM at 1750 and my 300 Utility at 2000. The early 300s were rated the same as the Farmalls 1750. The parts book does not show different planet or ring gear for the PTO so I guess to get the correct 540 on a 2000 RPM model you would just have to cut the RPM back to 1750.
randy hall
11-10-2002 18:37:50
utility tractors use the higher rpm rating.
Steven@nd
11-10-2002 15:27:22
weberstractorworks.com lists the max no load RPM at 1925.
If you have a rebuilt or in good condition engine I wouldn't be afraid of 2200, just be aware that the PTO will be well over 600 RPMs.
