Head Gasket
Bruce
11-11-2002 18:19:20
I may or may not have been successful in sealing the head gasket on my F30. The water in the radiator shows no bubbles at idle or even at moderate throttle. When running maximum throttle,
you can see occassional small bubbles. Is this
the head gasket leaking or is this from the agitation from the water pump? Hope somebody will respond. Thanks.
Al
11-12-2002 17:54:43
 Re: Head Gasket in reply to Bruce, 11-11-2002 18:19:20
Do a cooling system pressure test. You can get a colling system pressure tester. The small amount of air bubbles may just be cavatation from the pump. Napa also sells a kit to test if you have combustion gasses in the coolant.
Robert
11-11-2002 19:21:36
The proof will be in checking the oil pan for water.
