666 TA Replacement
HELP
BIG JOHN
11-12-2002 08:05:54
A good friend has a 666 that he uses almost everyday in his cattle feeding operation and the TA is just about to go out (been well used). Because of the demands on his time he needs to hire someone to replace it for him reather than do it himself.
The local CIH dealer gave him an estimate of $3000. Because the value of the tractor in good working order is only about $3000 he is reluctant to spend this amount to fix the tractor.
Here are the questions:
Is this a fair estimate of what the cost would be????
Could he expect a nondealer (independant) shop to be cheaper????
What should the cost of the parts be???? What would the labor run???? How many hours labor would be involved????
He would appreciate your input on this!!!!
THANKYOU
Rich
11-12-2002 21:02:36
 Re: 666 TA Replacement - HELP in reply to BIG JOHN, 11-12-2002 08:05:54
I did a customers 656 this spring,ta,clutch,new flywhl,etc.,a little over 2800.00. I am independent in Ia.
Red Rider
11-12-2002 20:42:11
I think 3000 dollors is a little steep even with the labor. When I replace my TA I went with the HD sprague unit, new HD main and TA clutch discs new throw out bearings, new HD pressure plates and turned both fly wheels for 1000 dollors doing all the labor my self. So $2000 for labor sounds high. I'd sure like to do the job for 2000 dollors plus parts.
RickB.
11-12-2002 14:54:13
Dealers have to predict the worst case scenario, or should. Are they estimating a main clutch and Pressure plate, pilot and release bearings, refacing the flywheel, new rear main engine seal, new IPTO shaft, refacing the TA flywheel? What type of replacemant TA is priced out? Without knowing what work was estimated, it's impossible to say whether it is a decent value. Dealerships will usually have the highest rates, but are usually better equipped, and should be more timely and stand by their work better to be competitive with their local market. And yes, I work at one.
AceS
11-12-2002 10:10:27
I would think $3000 would be high don't know cost of parts, 16 - 18 hours should do the job if one has the right equipment that would be a clean tractor at $50 an hour that is 800 - 900 labor.
SuperCmore
11-12-2002 13:40:28
 Re: Re: 666 TA Replacement - HELP in reply to AceS, 11-12-2002 10:10:27
Just a quick note...WHY would IH have ever given a tractor the 666 number??? Strange..Cmore
Rich
11-12-2002 20:58:37
 Re: Re: Re: 666 TA Replacement - HELP in reply to SuperCmore, 11-12-2002 13:40:28
I did a 656 this spring,Ta,clutch,new flywhl,etc for a little over 2800.00. I am independent shop.
RossMN
11-12-2002 18:18:09
a friend has one calls it the beast a title more deserving to ther 2470 Case (one of those weierd all wheel steer jobbers) in my own opinion
BIG JOHN
11-12-2002 08:08:21
Couldn't get the back button to work on this post to correct the spelling and tell you that we are located in NE Kansas. THANKS
