Will an M drawbar fit a,,,
Bryce Andreasen
11-14-2002 17:15:16
I am looking for a Farmall 400 with a farmhand loader(stronger hyd.) to clean out stalls in our feedlot. But when the county fair starts i want to be able to pull with it but I they wont let me pull with a two point hitch that can move. There is a tractor graveyard about thirty miles away with tractors anywhere from the 40's to the 80's tractor. Would a Farmall M drawbar fit a 400 or 450? It wouldn't be the actual drawbar just the bracket hooked up to the axels. Than we will just hook up to a solid metal plate bolted to it.
Steven@nd
11-14-2002 17:16:38
 Re: will an M drawbar fit a,,, in reply to Bryce Andreasen, 11-14-2002 17:15:16
Yep, M thru 450 parts are interchangeable.
Brian Banks
11-15-2002 05:43:47
 Re: Re: will an M drawbar fit a,,, in reply to Steven@nd, 11-14-2002 17:16:38
you can put the draw bar on but just putting a plate on it to pull from will not work. The old M's had a tongue that went to the belly of it so you are pulling from the center of the tractor. You will probably brake the system you are thinking of doing.
Old Hand
11-15-2002 07:30:22
 Re: Re: Re: will an M drawbar fit a,,, in reply to Brian Banks, 11-15-2002 05:43:47
If I had minimum wage for every hour I have ran M pulling from horseshoe drawbar I would think I am rich. The only time I have seen one break is when pin hole was almost worn through weakening horseshoe.
306 m puller
11-15-2002 06:30:26
i got an M last summer that had a busted drawbar and bracket. To get me through the summer i got the brackets and drawbar off of a 350. the brackets have 3/4 bolts instead of 7/8 and it held up with no swinging drawbar in 5500 and 6500lb class, so i think that you will be fine. my 2 cents
