Hyd. on '41 H
Bryce Andreasen
11-14-2002 17:21:18
I have a '41 H with a 3-point with double cylenders. I can lift the front end of the tractor up two feet up off the ground and not even full throttle! But i try to lift a ten foot disk with a separate hose and cylender and wont even begin to lift. There are two elbows on the left side of the pump and one on the right that i am currently hooked into. I hooked the hose up on the front left one and had a better effor but still wouldn't lift. any suggestions?
Bryce Andreasen
11-15-2002 08:34:50
 Re: Hyd. on '41 H in reply to Bryce Andreasen, 11-14-2002 17:21:18
yes there is only a single cylender on the disk and i took the top plug off to let it breath. It is just a little bit smaller than the 3-point. I am going to buy a 400 or 450 with live two way hyd. this winter so it isnt realy bad even since it's beginning to be winter and so cold!
Steven@nd
11-14-2002 17:26:14
Are you using a double or single acting cylinder? If you are using a double acting cylinder do you have an auxilliary spool valve or a breather in one of the ports? Perhaps the cylinders on your 3-point are larger than the one on the disk? Just need a little more info...
