Bad Gas Tank on a H
BIW
11-17-2002 19:48:50
I have a 1940 H with a gas tank that is rusty and full of crud. i but acid in it to it the junk away and it did the job but now it want's to rust. is there anything that recondtion's gas tanks. NEED HELP
olen
11-20-2002 09:15:54
 Re: Bad Gas Tank on a H in reply to BIW, 11-17-2002 19:48:50
biw,check out the web site at evapo-rust.com,this product will do the trick and is good for more things that are rusted.there is a pistol on there that i fixed for them,any questions ,call the company,good luck,olen
Guy
11-18-2002 11:39:28
Heres what I did a long time ago a is holding up well:
Put about 5 lbs of sheet rock screws in it along with water a straped it onto my cement mixer. let it tumble for a few hours. Then put a gallon or muratic acid it and sloshed it around. Dryed it out by putting the air compressor hose it at about 15 psi and let it run for a while. Then used a kit from Eastwood Company for lining it. Follow the directions with the kit, It comes metal wash, etcher and sealer. (p/n 10165z about $40)
www.eastwoodcompany.com
Andy
11-18-2002 06:50:42
Try POR-15. They sell a kit that includes a cleaner, etching material and the sealeant. Had a bad tank on a 36 BO and it worked perfectly. Jus follow the instructions. WWW>GETRUST.COM
Stan
11-18-2002 06:44:21
I believe the stuff that motorcycle shops sell is called Kreme. It may take a couple of packages for a tractor tank.
Robert
11-18-2002 06:08:56
Check this out:
theshopproducts.com
jimbo
11-18-2002 06:07:14
send tank to the repair shop and they will completely redo your tank--phone no. is 217 595 5403--Those old tanks cause a lot of problems with those old tractors.
Slappy
11-18-2002 04:09:25
I would go ahead and spend the extra money and have the tank sealed so you won't have any further problems. The Eastwood company sells a kit that does a great job. I've used it on my tractors and have no complaints.
http://www.eastwoodcompany.com/
Vern
11-17-2002 22:13:26
Motorcycle shops sell a product to put into the tank that coats the surface to prevent rust.
