Width of farmall 400
Bryce Andreasen
11-22-2002 19:11:40
I need to know the width of a farmall 400 series tracor
The Dukester
11-23-2002 18:23:16
 Re: width of farmall 400 in reply to Bryce Andreasen, 11-22-2002 19:11:40
The rear axles are 84 inches tip end to tip end, but you have to put the wheels in a "dished in" configuration 'cause they'll be wider than that in any "dished out" situation. 450s could be set real narrow if they had power adjust rims.
The Dukester
Hugh MacKay
11-23-2002 18:54:23
 Re: Re: width of farmall 400 in reply to The Dukester, 11-23-2002 18:23:16
Any Farmall with 84" axles can have wheels dished out and be no wider than the axles themselves.
Fudd@Work
11-22-2002 21:35:33
If the wheels are inside the rear axles, let me know and I will measure my 400 to let you know the width axle end to axle end.
Fudd@Work
11-22-2002 22:19:19
 Re: Re: width of farmall 400 in reply to Fudd@Work, 11-22-2002 21:35:33
Please see your post from this morning as that info is provided.
Red Rider
11-22-2002 19:40:55
Well Bryce that depends on what configuration your rear wheels are in. If you have the dish turned in, the width then will depend on the length of your rear axles.
