Super C
Armin Hesterber
11-25-2002 06:13:10
I am looking for a Super C to work on , but was wondering how much horse power it has , and does it have enough to pull a 6' belly mower with no problem?? Appreciate any help, thanks
Dave_Id
11-25-2002 06:23:07
 Re: Super C in reply to Armin Hesterberg, 11-25-2002 06:13:10
24.45 hp on the pto, that should be plenty to run your belly mower... I'm in the northwest, I have one I'd sell... if you are close and interested, email me..
Steve Mason
11-25-2002 06:20:43
Drawbar..... .... 21 hp Belt Pulley..... . 24 hp Maximum Pull. N/A Bore & Stroke. 3 1/8 x 4 Rated RPM..... 1650 Gears..... ..... .. 4 forward 1 reverse Basic Weight... 3209 lbs. Test Weight..... 4125 lbs. Front Tires..... . 5.00 x 15 Rear Tires..... .. 10 x 36
Good Luck on putting a belly mower on one of these - You might want to post a message to see if anyone has done this. Looks like a nightmare to me since there is no forward PTO.
Good Luck!!
CNKS
11-25-2002 18:24:31
 Re: Re: Super C in reply to Steve Mason, 11-25-2002 06:20:43
Belly mowers are common on these tractors, I think IH made one and Woods still does. Drive belt is sort of complicated, you remove belt pulley, and install a v-belt, run it through idler pulleys to the 3 pulleys on the mower (Woods). Belt has to be kept very tight. I have one on a Super A.
