Glow plugs
bgraves
11-25-2002 23:03:29
i have a 560 farmall i have never owned a diesal before when i go to start it it spits stutters and hardly runs then dies . then i do it again after about 3 times of doing this it will finally run . how long are you to hold in on the glow plug button before you atempt to try to start it and do you continue to hold button after it has started please help
ronohio
11-29-2002 15:04:56
 Re: glow plugs in reply to bgraves, 11-25-2002 23:03:29
What is the significance of the meter on glow plugs on a 560? Is it supposed to be high or low when it has been held on long enough or does it tell you nothing except they are on? Thanks, Ron
Jason B.
11-27-2002 06:03:24
I hold the glow plug button on my 460 for about a minute then as it is sputtering hold the glow plug button till it can idle on its own. some times it helps to give it a little fuel while its trying to start.
Jason B.
11-27-2002 06:02:45
Jason B.
11-27-2002 06:01:53
tractorval
11-26-2002 10:24:53
Make sure all six of the glow plugs are working. You can get by with one not working but if you have 2 of them that happen to follow each other in the firing order, you will have a tough start. On my 560 with rebuilt engine I still need to hold glow plugs for 1 min. in the summer and up to 3 min. when it's 20 below zero. However, she always starts. If you need advice on checking glow plugs, e-mail me.
Mike ISW
11-26-2002 08:03:33
Hold glow plugs for approx. a minute and hit starter. Continue to hold glow plugs until engine smooths out and exhaust clears of white smoke.
Red Dave
11-26-2002 07:03:27
Most diesels with glowplugs I am familiar with call for at least 1 minute, sometimes more.
Look at your watch while you hold the glow plug button. A minute takes longer than you think, especially when you are in a hurry.
Older, more worn engines seem to need more time on the glowplugs.
At least that's how it seems to me.
Michael Soldan
11-26-2002 06:06:29
B Graves, I have a B250 and it has been starting well in cold weather. I hold the glow plugs on for about 30 seconds, then hit the starter while still holding the glow plug lever down and I continue to hold it down until I get rhythmic firing and the engine begins to run on its own. That's a cold weather start. Interestingly enough I have a 584 with no glow plugs, no heater and it will start as easily when its 27 below as when its 85. I don't understand that concept but am sure happy with it. Good luck from Mike in Exeter Ontario
Steven@nd
11-26-2002 05:53:24
Up to 3 minutes of glow plugs on a cold start. Takes about a minute of glow plug on a warm start. This is my experience with a 660 diesel, same engine.
