Would it be easy to,,,
Bryce Andreasen
11-26-2002 17:49:14
I am going to buy a Farmall 400 hopefully tomarrow. I want to turn the two point into a three point. A local blacksmith can make the bottom two links but how easy is it to make the top link bracket? Can you buy something at a Case IH dealer?
Guy
11-27-2002 07:49:19
 Re: would it be easy to,,, in reply to Bryce Andreasen, 11-26-2002 17:49:14
I've seen the 300's and 400's with different types of fast hitches. Some have a exposed rock shaft that a bracket can be mounted on. Others have threaded holes in the differental casting where a bracket can be bolted on. I have a early 300 which doesn't have either of these. I had to fabricate a mount that bolts on which works good.
If you want a picture let me know. You can also check out www.worksaver.com - they have some 2 to 3 pt. conversions.
Red Rider
11-26-2002 20:48:54
IH made a 2 point to 3 point conversion (Part # 522076R91). This adapter plugs into your 2 point and has receptacles for the lift arm pins and top link. What I have done is put an adapter on every piece of equipment that I have. I sure is easier to just back into the adapter lift and go that mess around with trying to aliegn three point equipment. If you have never used your 2 point then you don't know what your missing.
joe
11-26-2002 17:53:04
you can even buy kits for exactly this, they have the two bottom prongs and something you bolt on for the top link. I forget how the top link works on the 400, but it somehow bolts on, or hooks onto the rockshaft.
