Super C ignition coil
Bob Roane
12-02-2002 05:24:38
Can anyone tell me a good ignition coil to use for my Super C? Also, a couple of years ago, I had it changed from a 6 volt system to 12 volt. I don't think the ignition coil was changed at that time. Should it have been? Would a new coil make for better starting? Any help would be appreciated.
Bob Roane
BIG JOHN
12-02-2002 18:02:16
 Re: Super C ignition coil in reply to Bob Roane, 12-02-2002 05:24:38
If the 6 volt coil was left on your tractor without adding an external resister then you have probably burned it up by now. If you install a 12 volt coil with an internal resister you will ready to roll. NAPA has them on their shelves. GOOD LUCK
