Magneto tune-up
AGR538
12-02-2002 08:33:04
My H has an international magneto. I have replaced the points but I cannot figure out how to remove the condensor. It appears there is a cover on the block side of the magneto but there is not enough space between the block and magneto to remove it on that side. Also, it does not appear I can remove it on the other side. Any suggestions?
Haas
12-02-2002 16:14:56
 Re: magneto tune-up in reply to AGR538, 12-02-2002 08:33:04
You have to take the magneto off the tractor to remove the condenser. That means you have to set the timing when you put it back, but if you replaced the points, you need to do that anyway.
