How many felt O-rings does the M farmall pto have?
aaron
12-02-2002 17:45:59
As my shaft seal was leaking I took mine off and counted three? So, where do I place my replacement rubber O-ring? Do I knock all the felt ones out and just insert the rubber re-manufactured one?
-aaron
12-03-2002 18:18:37
 Re: how many felt O-rings does the M farmall pto have? in reply to aaron, 12-02-2002 17:45:59
what part of the world are you from that you would call a seal a felt o ring?
The Red
12-03-2002 09:36:22
The seal on Old Raceway M was a double seal in a single assembly. I replaced with 2 of the thin seals.
Farm-M
12-02-2002 19:03:02
I replaced mine, had 3 just like you were describing, went to IH dealer to get part and new part was a single modern type wiper seal just like the front seal on a car engine. Mounts flush with housing, works perfectly.
Bryce Andreasen
12-02-2002 18:51:04
I have an H but we took it apart to replace the seals and there were two original ones. We just put one new one in and it works fine.
CNKS
12-02-2002 18:13:33
I have not done one on an M, so I could be wrong, but my parts book shows a single oil seal (Probably leather, new one will be rubber). No felt. Part # 45702 D, new one will have a different part #. Sounds like someone was trying to stop the leak with felt, which is really more of a dust shield. You will also need a gasket --66347 D.
