Int 10' Grain Drill
Avery
12-03-2002 06:34:05
Anybody know anything about an International 10' grain drill. Specifically one without the hydraulic cylinder. Did'nt they make this drill with and without the hydraulic cylinder. The ones without had a hand lever for engaging and disengaging the discs did'nt they? I have a chance at one of these drills but it's missing the lever to engage disengage the discs. Can you still get this part and if so any notions as to price range or availability. Drill needs some work, but body is in good shape no rust. Would appreciate any ideas. Thanks
JD
12-03-2002 14:42:30
 Re: Int 10' Grain Drill in reply to Avery, 12-03-2002 06:34:05
Does that grain drill have power lift? Or are you talking about hand lift.
IH made the model M. If it's a real old M it could have hand lift.
You could also get a Hydraulic lift attachment for the moael M. I had a 8ft and now i have a 10ft model M. My 8ft and 10ft have 2 levers. A clutch on each side.
If you drill has clutch type power lift with 2 levers, i think i have the levers from my old 8ft. They say you cant get parts for the M from CaseIH
Avery
12-04-2002 07:02:25
 Re: Re: Int 10' Grain Drill in reply to JD, 12-03-2002 14:42:30
Drill is hand lift would like to get it running but don't want to spend an arm and a leg. Not exactly sure what model. Will find out. Think 140 would pull it ok?
JD
12-05-2002 13:55:25
 Re: Re: Re: Int 10' Grain Drill in reply to Avery, 12-04-2002 07:02:25
I'm sure a 140 will pull it but not up a big hill.
Sven
12-03-2002 13:52:56
What model is yours? I have an International 100 double disk press drill that I have been rebuilding and am missing the hydraulics on. The dealers don't seem to have parts for these anymore. My manuals show the manual lift you are talking about it also has a depth control device.
