C and Super C ---- Difference?
Armin H
12-06-2002 10:11:41
I am looking at buying a C or Super C and putting a belly mower under it, and was wondering what the difference is between the C and Super C, I know age, but what else??/ Thanks
Armin
Dave_Id
12-06-2002 12:09:40
 Re: C and Super C ---- Difference? in reply to Armin H, 12-06-2002 10:11:41
Check the archives on this one... many previous discussions on the differences, but Peabody got the main difference... but some of the last Farmall C's had the 123 engine too..
Peabody
12-06-2002 11:02:42
Pretty much the same tractor, but the Super C had a little bigger bore, therefore more CID, therefore a couple of more HP.(22 vs. 19, or thereabouts). Also, all Super C's had a water pump, while only some of the C's did (or were added later). C production years 1948-51; Super C's from 51-54.
Peabody
12-06-2002 11:18:51
 Re: Re: C and Super C ---- Difference? in reply to Peabody, 12-06-2002 11:02:42
Well, I just looked it up and the Super C was 21 hp (drawbar), while the C was 15. I didn't realize there was that much difference in power.
Armin H
12-06-2002 13:40:55
 Re: Re: Re: C and Super C ---- Difference? in reply to Peabody, 12-06-2002 11:18:51
Is there a difference in hydraulics? do they both have Hyd, or is one of them live??
19.6 hp Drawbar
12-06-2002 12:40:04
.. at 1650 RPM. Some very early 1948 C's had a 1540 RPM rating(vs1650 Later) and that was likely those early tests at Nebraska that gave the lower HP at the lower RPM. Now, 50 years later, they are probably all updated to 123 cubes so condition and RPM is likely more important than old HP-Tests. Disk Brakes were a big change. G
Peabody
12-06-2002 13:55:10
 Re: Re: Re: Re: C and Super C ---- Difference? in reply to 19.6 hp Drawbar, 12-06-2002 12:40:04
Oh, yeah, thanks. I forgot that the C had drum brakes and the Super had disc. They both have the touch control unit, which is a live hydraulic unit (The pump is behind the governor). Remote hydraulics were an option, and necessary for operating the fast hitch system. I sure wish my Super had remote hydraulics.
jal-SD
12-06-2002 14:59:31
 Re: Re: Re: Re: Re: C and Super C ---- Difference? in reply to Peabody, 12-06-2002 13:55:10
IMHO, the drum brakes make an updated C worth more than a Super C w/those WORTHLESS disc brakes on it. (My $0.02 worth. jal-SD)
Peabody
12-06-2002 16:02:35
 Re: Re: Re: Re: Re: Re: C and Super C ---- Difference? in reply to jal-SD, 12-06-2002 14:59:31
Hey, I'm kinda fond of my disc brakes. She turns on a dime. Oh, yeah,one more thing, the C has the "Farmall" emblem on the front, while the Super has the "IH" logo.
Stan(VA).
12-06-2002 19:20:40
 Re: Re: Re: Re: Re: Re: Re: C and Super C ---- Difference? in reply to Peabody, 12-06-2002 16:02:35
The only C model I have seen with the Farmall front emblem instead of the IH was in Guy Fay's? IH Prototype book. I currently have access to (3) '50s, and (1) '51 tractor that all have IH. I don't know of any '48 or '49 models at the moment. The change from drum to disc brakes was already stated as well as the change to larger sleeves and pistons, but along with the water pump came an engine temp gauge, hyd temp gauge, different thermostat housing, taller radiator, taller grill, and different gas tank (taller mounts). The hyd pump is below the distributor drive, the governor kind of hangs off the front. Not that we're into details or anything ;) ;)
Stan(VA).
Peabody
12-06-2002 20:22:53
 Re: Re: Re: Re: Re: Re: Re: Re: C and Super C ---- Difference? in reply to Stan(VA)., 12-06-2002 19:20:40
Ok, Ok, you proved you are a bigger C/Super C head than I am. Let's just get picky!!! Hey, I love them all, as I know you do, too! :) All in all, both are great little tractors.
Stan(VA).
12-06-2002 21:29:36
 Re: Re: Re: Re: Re: Re: Re: Re: Re: C and Super C ---- Difference? in reply to Peabody, 12-06-2002 20:22:53
Been a long day... Just having fun, my appologies if I pushed the envelope. If you saw my tractors you would know I'm nowhere close to the 'correct police'! My Super M is a stage 1/2 combo, SH and 504 are close to stock, my B is a rescued fence row reject that is now a 1940/41/46/50/51/53/61 (at least) combo of parts! But I love runnin around my little 'Super B' with live hydraulics and a 3 pnt hitch. Don't start me on the latest cub cadet projects;)
Stan(VA).
IH Badge on front
12-07-2002 00:58:01
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: C and Super C ---- Difference? in reply to Stan(VA)., 12-06-2002 21:29:36
My earliest C has the IH badge and its #584 built. I don't think any but the preproduction models had "Farmall" on front.
