Don't know how this happened!
Bob in SE Nebra
12-08-2002 10:56:04
I can't figure how the steering shaft got bent. The top end of the shaft that goes up into the gear box has a bad bend in it. It wasn't easy to get it removed from the bolster. I will go to my favorite tractor salvage yard tomorrow and get a replacement. (I was looking for an excuse to go there anyway) You may be able to see the bend in the picture. Any ideas how that happened?
Bob
Mguy
12-08-2002 20:06:30
 Re: Don't know how this happened! in reply to Bob in SE Nebraska, 12-08-2002 10:56:04
That a really late M you got there? Looks like disc brakes, is it? Mguy
Bob in SE Nebraska
12-09-2002 06:21:18
 Re: Re: Don't know how this happened! in reply to Mguy, 12-08-2002 20:06:30
This M has some kind of aftermarket brakes on it. I have only worked on the tractor long enough to get it started as I have spent most of my time working on an H. It looks interesting to me and I plan to check it out when I get a chance.
Bob
Don LC
12-11-2002 05:06:34
 Re: Re: Re: Don't know how this happened! in reply to Bob in SE Nebraska, 12-09-2002 06:21:18
Your brakes are IH, not aftermarket ....My late model 1951 M has disc brakes...this happened during the change over to disc brakes on the super M ..... Don
Zonie
12-08-2002 11:43:09
Bob, I have a twin to your pivot shaft laying in my scrap heap. I know what you mean about it being hard to remove from the upper bolster housing, Had to drive mine out with a sledge hammer and a block of hardwood.
The only thing I could figure out is someone must have run into something with the front tires.
My steering gear was also missing several teeth right in the middle of the gear.
The Red
12-08-2002 11:03:20
Take a look at your steering wheel pedastal and see if by chance it is bent. I had that same problem when I was tearing down Old Rusty H. The pedastal was bent big time forward towards the gas tank.
Bob in SE Nebraska
12-08-2002 12:16:36
 Re: Re: Don't know how this happened! in reply to The Red, 12-08-2002 11:03:20
The pedastal looks ok as far as I can see. Nothing seems bent or stressed in any way. I suppose someone just hit something hard with the tractor that caused the bend. Glad it wasn't me driving.
Bob
The Red
12-08-2002 12:30:35
 Re: Re: Re: Don't know how this happened! in reply to Bob in SE Nebraska, 12-08-2002 12:16:36
I'm sorry, I missed understood what got bent. I was thinking steering shaft between the steering wheel and the bolster. That bolster pivot shaft or the front wheels took a hard hit somewhere along the line.
Bob in SE Nebraska
12-08-2002 11:07:13
Seems to me I noticed something strange about the steering pedastal when I took it off. I'll go look now and add another log on the wood stove too!
Bob
Bob in SE Nebraska
12-08-2002 11:02:38
Missing link from post. (I hope)
