International 340 utility tractor-timing gears
bob bryant
12-09-2002 15:58:32
I'm working my way to the timing gear cover.Have removed tons of covers and the like.This tractor has the International loader attached.How do you remove the radiator?Is it attached to the front end support with those two bolts that you can barely get to?Thanks in advance---b0b
pj
12-10-2002 06:27:59
 Re: international 340 utility tractor-timing gears in reply to bob bryant, 12-09-2002 15:58:32
the 2 bolts under it has got to be loosened and then slide it out.you do not have to take them all the way out.good luck
